42-395 decal
Hi Neewbie here
Im looking for the 42-395 decal thats in the center of the cab its abouyt 2" although I think I could make anything work.
Thanks
paparoach
Antique Electronic Supply carries the proper PHILCO decal.
http://www.tubesandmore.com/
The part no. is S-M907 and includes a number of decals you won't need, but these are the only authentic-looking 1937 and later Philco decals I am aware of.
Radio Daze sells Philco decals, but theirs does not look authentic at all and therefore, I cannot recommend them.
