42-355T - wring rubber or not?
Is the wiring in the 42-355T rubber? I saw one yesterday, but I may not be able tor emove the chassis to check before deciding if I want to buy it.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Yes, it is.
All Philco sets made in the USA between 1939 (June 1938) and 1942 have rubber-covered wiring inside.
Just a FWIW here even though this does not apply to a 42-355, but most 1939 models even have rubber-covered wiring coming out of the power transformers.
Thanks. I've found one, along with something else I want in a shop, and will use that fact to get it cheap, or pass on it.
Well, good luck to you. Icon_smile
I mentioned the rubber-covered wiring being used in USA-made Philcos between 1939 and 1942, because I have a Canadian Philco 39-330AT which looks just like a USA Philco 39-25T but has a chassis similar to a 39-30T. One major difference - it has six pushbuttons instead of eight in the USA models. Also, all of the wiring under the chassis, with the exception of the two IF transformers, is cloth-covered wire. Only the wires from the IF cans had the dreaded rubber insulation. That made this set much easier to restore.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
