Electrolytics Replacement
I have figured out all the paper capacitor values for the underside of the chassis, my next question is about the electrolytic capacitors on top of the chassis. When I replace those I have noticed that modern electrolytic capacitors have two leads however these old capacitors have what appears to be one "nipple" on the bottom of the shorter capacitor labeled 16mfd and 4 leads on the larger capacitor labeled 8mfd 8mfd 10mfd. how do i go about connecting these new capacitors? Also, I cant seem to find out what the voltage for these capacitors should be.
What radio are you working on?
Carl
Northern Panhandle, WV
This is a continuation of an already existing thread:
http://www.philcoradio.com/phorum/showth...p?tid=2768
Please direct all replies to the previous thread as I am locking this one; multiple threads on the same subject are not allowed.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
