Need Help With ID and Schematic
Hi - New member here . . . I recently picked up a Philco integrated mono amp that was supposedly pulled from a record player. It's PP 6L6 with a pair of 12AX7s and a 5U4. The only number on the chassis is 7004298650. I did a search at the Sams site but got nothing. Does anyone here know what model this came from or have a schematic they could share?
Here's a link to a pic in case my attempt at attaching one doesn't work: http://www.flickr.com/photos/11175168@N02/5366251655/
Any help or info would be greatly appreciated!
Thanks . . . Charlie
Charlie,
Might be an E-1776:
http://www.radiomuseum.org/r/philco_e_1776.html
Carl
Northern Panhandle, WV
Thanks Carl! I haven't downloaded the schematic yet, but that certainly looks like the amp.
. . . Charlie
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
