Philco 90 (1-47 tube output) question
Was electronically replacing the copper electrolytics in my 90 model today. What I mean is that the caps are still there, just not functioning. The radio volume was starting to fade, and I wanted to do this before a real problem occurred.
My question is about the two condensers (#24 and #30) located in metal containers under the chassis. On the schematic I have (nostalgia air) #24 has 4 caps of .1, .15, .25, and 1.0 mFd, and #30 has .25 and 1.0.
1. My 90 has each of the caps with 3 leads, not 4 on #24 and 2 on #30. Any idea where the error is?
2. In any event, there is no listing of where the specific values are located on the schematic. You have 2 caps listed as #30, and 4 listed as #24. But there is no wasy to detirmine which cap is what value.
Never mind, I found the answer in the tech section.
Here's the link:
http://www.philcoradio.com/tech/90error.htm
Icon_smile
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
