Speaker connector?
Working on a Philco G1528 auto radio. Need a connector for the speaker leads. The socket on the cabinet is a round plate with 3 holes of approximately 1/8 inch dia for the plug pins.
Does any one know where I can get something to fit? Or what to use/make?
Thanks
Gary
Have used pins from a Molex connector to make up odd connector. Can be had a RS and come in two sizes. They can be expanded with a little bit of prying with a small screwdriver.
I should have thought of the Molex connector pins. Have several in the junk box.
However I since tried an RCA plug and the pin is a perfect fit! Just had to grind off and remove the metat ring and the plastic and now have a nice pin to use.
Thanks for the suggestion. You might want to check out the RCA pin.
Gary
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6161 online users. [Complete List]
» 1 Member(s) | 6160 Guest(s)
