I recently purchased a 42-380 for $40 at an estate sale, the only issue I see is the face plate on the cabinet. Would anyone happen to know where I might be able to find one of those as well as the knobs for it.
Thank you,
Daniel in Louisville
Sorry, I see no one has given you the info, so here it is:
Radio Daze still has stock of the reproduction escutcheon for this model; part no. ES-PHIL42.
http://www.radiosupply.com/product/1071.aspx
They also carry the reproduction knobs for this model:
http://www.radiosupply.com/product/1074.aspx
Thanks Ron, very helpful. That is exactly what I'm looking for.
I also have a color picture of a D-717 if you'd like to use it:
[attachment=0]
Thanks Again,
Daniel
Thank you, Daniel!
PM forthcoming about the photo.
