Threads: 40
Been awhile ... but i found a nice 60- 505.
When i go to Nostalgia air ... would i go to model 60 for schematics?
Thanks for any info.
Yes, you will find it listed there under Model 60.
http://www.nostalgiaair.org/Resources/793/M0013793.htm
Don't forget, Model 60 underwent numerous changes during its nearly three year production run. All of the changes are documented here:
http://www.philcoradio.com/tech/60evol.htm
Threads: 40
Your the man thanks a bunch.
Looked mine is the 60b 1936
Threads: 268
Hi Denver
If this old gal gives you trouble double check the oscillator coil they can be a problem on this model.
Good luck w/it
Threads: 40
Will probably wait till .. winter again to work on.
Get me another or two.. have some projects for cold season.
Order tubes ect. have everything ready.
Thanks for info.
