46-420 Code 125 Replacing Cap with wire coil
I am in the process of recapping this "Hippo" and ran across this cap with wire coiled around it. It is an original Philco cap stamped with .2mfd 400 wv.
Here is a picture of the cap.
Can I use just a regular .22 mf mylar cap to replace and what do I do about the coil?
Thanks- this is my first post here so I hope I did this correctly,
Frank
Hi,
We've been discussing this same part in this thread:
http://philcoradio.com/phorum/showthread.php?tid=3609
Hopefully this will help you as well.
Thanks Ron, I may try just replacing with .22 leaving the coil off and see if it creates any problems. If it does I'll have an idea what might be causing them.
Frank
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7895 online users. [Complete List]
» 1 Member(s) | 7894 Guest(s)
