Philco 46-480 C206 1200VDC ?
While recapping a Philco 46-480, I noticed that the old C206 working voltage was rated at 1200 VDC. The rest of the 0.006 caps were rated at 400 VDC and they all have the same part number on the parts list. Does anyone have any idea why C206 would be rated for 1200 VDC? I assume I need to replace it with one with the same voltage rating.
Thanks for any advice.
Jim
It may have been a replacement part long ago and that's what was on hand. Some circuits have a high peak voltage like the plate of the audio output tube. It's not just the plate voltage there's an ac component and the audio voltage. 1.2kv is bit high.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6951 online users. [Complete List]
» 2 Member(s) | 6949 Guest(s)
