Rubber washers,Philco 16X
Have a nice 16X console I want to restore and noticed the rubber insulators under the tuner are deteriorating and the tuner is loose.
Looking in the front dial, it looks like the tuner is sitting about 1/4 inch too low.
Same with e 4 rubber insulators on the corners of the chassis.
Anyone know the thicknesses of these insulators so I can make new ones?
Thanks for any advice.
murf
Look for the specs here
http://www.renovatedradios.com/parts.html
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 3562 online users. [Complete List]
» 2 Member(s) | 3560 Guest(s)
