Model 46-1213 Record Changer M-4 Substitute
I am hip deep in the restoration of the 46-1213 and have a question regarding the changer. It is a Model M-4, operating at 78RPM. My question is is there a later unit that can be substituted that operates by 33 and 78 RPM. Such as shame to just have 78, while I have many 78's, many more 33's.
Thanks and Happy Halloween.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 3833 online users. [Complete List]
» 3 Member(s) | 3830 Guest(s)
