antena
hello i need help with wiring for my antena on a philco 37-60 what connections do i use there are four and do i have to run a ground wire? would some one please explain the process.
thank you.
tom.
Antenna coil or just to hook up for reception? The coil connections would be shown on the schematic, there should be only two for antenna conection 1 clip for the wire and 1 clip for the ground.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 3845 online users. [Complete List]
» 2 Member(s) | 3843 Guest(s)
