Philco's oldest FM set?
What is Philco's oldest FM table and console radio they made that received the modern FM frequencies?
-Keith
Oldest consoles: 46-480, 46-1213 (1946 models)
Oldest table models: 48-472, 48-472-I, 48-475, 48-482 (1948 models)
I have 3 of the 46-480 consoles. They are nice looking sets. I was really surprised how well the set pulls in stations on FM with a cheap dipole antenna. Of coruse, the loctal sockets are a real joy. Jim
Thanks for the info guys!
-Keith
Philco 91 Tuning Condenser
There are currently 5372 online users. [Complete List]
» 1 Member(s) | 5371 Guest(s)
