Philco 116X followed me home today
I picked up this 116X off of CL today. All in all it's in nice condition and appears unmolested. I think this one's a keeper. Icon_thumbup
[Image: http://i863.photobucket.com/albums/ab191...16x-1s.jpg]
[Image: http://i863.photobucket.com/albums/ab191...16x-2s.jpg]
Larry
Looks in great condition. Makes you almost want to get two so as to display the back too.
Nice set! They are a great radio!!
Looks about the same condition as my 116X I found off CL over a year ago. Looks like you will need some grill cloth like mine as well. I swear, every Philco I have seen with this type of cloth nees help. Must be the cloth. One word of wisdom, watch that speaker cone for a bit when you get it going. The 116X can get loud and sounds good, but mine formed several cracks in the speaker cone along the edge from the first few hours of play. Luckily I had to take the speaker back out to inspect it or I would have had alot worse to repair. A little speaker repair cement and mine has held fine so far.
Uffda Wrote:Looks in great condition. Makes you almost want to get two so as to display the back too.
I do have a second one. How would they look together? Icon_biggrin
[Image: http://i863.photobucket.com/albums/ab191...116x-1.jpg]
Larry
looks good its on my bucket list...Icon_smile
"No, really! I bought the second one so I knew what the first one was supposed to look like!" Icon_biggrin
Nice job!!!!!
Looks like it's in great shape too. Hopefully the junker has a good pair of 6A3's those darn thing ain't cheap! I just got a 37-116 standard model.
Nice! I have one of those little gems tucked away in my radio room also8)
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco 91 Tuning Condenser
