how to remove the cap on volume/power switch on Philco Mystery Set
Some of you might already know this.
I stumbled upon something today that I thought might be useful to others. If you ever find yourself overhauling one of Philco's Mystery Control sets (39-55, 39-116, 40-205 ect..) you will have a lot of rotten rubber wire to replace. Two of those rock hard wires lead to the power switch which is on a little platform and attached to a motor through a bunch of gears.
I originally thought that the switch would have to be taken apart to replace the wires for the power switch, but it turns out the cover is just a cap that can be pried off. This makes it super easy, and I missed this on my 39-116 which I’ll have to go back to and replace the wires I just slipped heat shrink over in the past.
Check out the pics.
Switch and motor assembly:
[Image: http://i1129.photobucket.com/albums/m501...b7274c.jpg]
Closeup of power/volume switch:
[Image: http://i1129.photobucket.com/albums/m501...5624e8.jpg]
Popping the cap off:
[Image: http://i1129.photobucket.com/albums/m501...4346e4.jpg]
[Image: http://i1129.photobucket.com/albums/m501...0b1458.jpg]
Cap off and power terminals exposed:
[Image: http://i1129.photobucket.com/albums/m501...1d28f3.jpg]
-Keith
Thanks for posting this, Keith. Icon_thumbup
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8208 online users. [Complete List]
» 2 Member(s) | 8206 Guest(s)
