Philco 60 resistor wattages?
Hello all,
This is my first post. I am working on a Philco 60. I've noticed a few of you have restored this great old radio and was hoping I could get some help on the proper wattage of the resistors. As you know, this information is not given in the schematics. It was suggested by someone on the Antiqueradios forum that they routinely replace the flexible wire-wounds with 2 Watt and suggested that 2 Watts would work for all the resistors in the chassis.
lyle
I may not be very good, but I'm slow.
Here, this might help. http://www.philcorepairbench.com/resistcompare.htm
M R Radios   C M Tubes
(02-29-2012, 05:44 PM)Steve Davis Wrote:  Here, this might help. http://www.philcorepairbench.com/resistcompare.htm
Thanks, Steve
I just found the values on the Philco parts values on the PhilcoRepairBench page.
Between you and that I think I've got it.
Thanks again, Steve
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8177 online users. [Complete List]
» 1 Member(s) | 8176 Guest(s)
