I stumbled by this site by accident most of you may be aware of it but thought I'd post it for those like me who were not. There are a couple philco dials listed.
http://www.indianaradios.com/bin/images/large/
Philco 91 Tuning Condenser
There are currently 5358 online users. [Complete List]
» 1 Member(s) | 5357 Guest(s)
