1935 model 18 trim color
I am about to restore a model 18 scalloped cathedral cabinet that has lost most of its original finish, in the pictures I have seen of the 18, 118, 144 the two lines/grooves under the bottom row of knobs look to be reflective in the photo. Does anyone know what color was used in these two trim lines?
Thanks, Todd
Light Tan.
(05-01-2012, 02:30 PM)TA Forbes Wrote:  Light Tan.
Thanks
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 2936 online users. [Complete List]
» 1 Member(s) | 2935 Guest(s)
