Which decal is correct for 45C?
Just about to finish up restoration of my butterfly radio and was trying to find the correct decal. Anyone know which Radio Daze decal to order? Looks like maybe PH8?
Frank
Definitely DCL-PH8.
Thanks Ron. I'll get it ordered and finish this set.
Frank
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 2942 online users. [Complete List]
» 1 Member(s) | 2941 Guest(s)
