A good "touch-up" stain
I used this stain on my 47-1230. It matched perfectly. Used it to restain the base, where the wood was rotted and the stain was all gone (it must've sat in some water for a while). I then took some of this stain on a cloth and wiped it over the entire cabinet. It did a GREAT job of staining the age cracks / scratches / chips!
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
There are currently 2856 online users. [Complete List]
» 3 Member(s) | 2853 Guest(s)
