Source for RADIO BACKS
Just want to make members aware of a NEW Fantastic source for Radio backs.
Recently received a PT -25 back for a Philco from this site.
Dan is very good to work with. Send him a scan of what you have and he will be happy to laser cut one.
Check out his site some backs now available.
The back for the Boomerang 49-501 is available.
http://www.radiobacks.com
Cheers,
JB
