  • 1 Vote(s) - 5 Average
Philco 623 cabinet restoration
Here it is with the masking paper removed and the decal applied. I'll apply a few more coats of clear gloss over the weekend.
[Image: http://farm9.staticflickr.com/8066/81707...78af_z.jpg] [Image: http://farm9.staticflickr.com/8204/81707...4478_z.jpg]
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
