Connection for Philco 95 #3754 B+ recap
I cleaned out the B+ can and I have the service data for the model 95 and it appears that I should make these connections,
lead 1 -0.05uf cap to chassis ground (lead 11)
lead 2 -wire connection to lead #1
lead 3 -2.0uf connection to lead #10
lead 4 -0.5uf to chassis ground (#11)
lead 5 -0.15uf to chassis ground
lead 6 -0.5uf to chassis ground
lead 7 -1.0uf to chassis ground
lead 8 -0.15uf to lead #9
lead 9 -2.0uf to lead 3-10 after 2.0 cap
Have I correctly decoded the chart?
Claude,
Use the schematic diagrams here on Ron's site to double-check. The can terminals and cap values are listed on the schematics for both versions of the Model 95.
Here is the Early Version:
http://www.philcoradio.com/tech/images/95e.jpg
...and the Late Version:
http://www.philcoradio.com/tech/images/95.jpg
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9530 online users. [Complete List]
» 2 Member(s) | 9528 Guest(s)
