Clear coat over stain??
No, it won't be exactly like the original - in fact, it won't be anything like the original, because tinted lacquer was used at the factory, not stain. Icon_confused
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 3072 online users. [Complete List]
» 1 Member(s) | 3071 Guest(s)
