Dial light bulb for Philco model 66
I just acquired a beautiful Philco model 66 - it did not have a dial light bulb in it - What # bulb does it take? Thanks, Phil
If you look at the parts listing, it says p/n 6608. Cross-ref to the pilot lamp table on my site shows it's equivalent to a #46 lamp.
There are currently 9375 online users. [Complete List]
» 1 Member(s) | 9374 Guest(s)
