38-17F
Does that thing have any photofinish on it??
Tnx
38-18??? Do you mean perhaps the 38-17 you recently purchased?
If so, then yes, I seem to recall that the front panel of the set does indeed have photofinish; the rest of the set does not, I think.
Yup that's what I meant. Your a mind reader! Tnx I thought I'd ask before I started with the stripper.
I updated the title of this thread to avoid confusion. Icon_smile
I suggest you check and see if the front panel is held in with screws; if so, it might come out easily if you remove the screws. If it does, then you could feel free to use your favorite stripping chemical(s) on the body of the cabinet while you store the front panel away safely somewhere else.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
There are currently 2730 online users. [Complete List]
» 4 Member(s) | 2726 Guest(s)
AvatarAvatarAvatarAvatar
