38-12 Field Coil rebuild?
I'm restoring a 38-12 which has an open field coil. The speaker cone is like new and audio the transformer appears good. I would prefer not the convert to a PM speaker. Can the field coil be repaired? If anyone has attempted to repair the field coil on this or a similar unit (Speaker model BO-1, p/n 36-1366), I would like to hear from you. Suggestions, including dissassembling the speaker and rewinding the coil, would be very much appreciated. Thanks!
Ed, I believe the concensus of opinion is that if the break in the coil is not near the ends and you can resolder leads, you will have to replace it. The way its mounted on the speaker makes it difficult to remove. Usually force fit rivits. Check near the end, look for greenish coloration indicating a spot where its corroded through. PL
Thanks. I was afraid that would be the verdict. It went up in smoke so I guess it's toast now. And a shame because the cone looks perfect.
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
