38-690 New questions
As I progress through this radio, I find myself in need of a few things. The first of which would be a voltage chart. Does anyone have access to one of these?
Also, Looking at the dial mechanism, I can't quite figure out how to get it apart, and it does need to come apart so I can replace the dial scale (one of Mark O's great repros is on order).
I can't wait to get in my replacement e-caps so that I can get to restuffing those old cans.
Brenda
The Service Bulletin for the Automatic Tuning models, including the 38-690, gives lots of detailed information on servicing the mechanism including how to disassemble it to get to the dial scale. You can download a copy here:
http://www.philcoradio.com/phorum/showth...p?tid=5938
As far as I know, only a limited amount of information was ever published for the 38-690 - a schematic, an under-chassis diagram, a parts list, and alignment info - nothing more.
Thanks, Ron. That will be a big help. Icon_smile
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2974 online users. [Complete List]
» 4 Member(s) | 2970 Guest(s)
AvatarAvatarAvatarAvatar
