Transitone PT-63 Project Modification
I am just now getting into electronics and I found a Transitone PT63. Was wondering if the Phorum would know about the four prong cable coming from the back. What is it? Can it be converted to a modern power cable? Also I am interested in converting the input and output into a 1/4" jack? I want to use it as a tabletop tube preamp.
That four prong cable is for a battery pack - the PT-63 is a battery-operated portable radio.
http://www.philcoradio.com/gallery/1940b.htm#b
You might want to find something else for your project.
I think this set would be completely useless for making into a pre amp, you could do it but it's like a shovel with a rope handle. If you want a tube pre amp either find an old factory built one or start collecting parts and build one from scratch. I often suggest pulling the tube amp out of a junked cabinet stereo from the early 60s, there are lots of those units around and most people can't even give them away if they are rough cosmetically.
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2818 online users. [Complete List]
» 4 Member(s) | 2814 Guest(s)
AvatarAvatarAvatarAvatar
