Lamp for Philco 46-427
The schematic for this set calls for a I100 bulb for the panel light. It is a bayonet type but not a 44 or 47 6 volt bulb. Anyone knowe what it is? Thanks - Joe jdgatto@earthlink.net
Joe,
P/N 34-2068 is supposed to be a type 47 bulb:
http://www.philcorepairbench.com/lamps.htm
Carl
Northern Panhandle, WV
Thanks Carl. I see my mistake now. When I first tried a 47 it blew out immediately, probably a fluke. I then went to a 44 but that draws too much current. Will go to radio shack and pick up another 47 and try again. Joe
I100 is the schematic/parts listing designator - Indicator (lamps) 100.
Just like L for coils, T for transformers, C for caps, etc......
Chuck
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2727 online users. [Complete List]
» 3 Member(s) | 2724 Guest(s)
