Dial Philco 66S and dial philco 66B
hello i have two tombstone philco, but they have diferent dial, the Philco 66s have the scale dial number 27-5081 and the philco 66b have the dial 27-5057, some have this radio ????
are originall this dial of ths two radio ??????????????
thank you, Mauricio
Hi Mauricio,
The information I have access to says the dial for the Philco 66B is indeed part number 27-5057. This is a tombstone radio with the small window for the dial - is that correct? (Philco also made a cathedral radio with this model number). Here's a picture of the 66B from Ron's website.
http://www.philcoradio.com/gallery/1935a.htm#ae
The 66S has a much more ornate grill than the 66B, but I don't have any other specific info on it. I'm sure there is someone here that has access to better info than I do. Here's a picture of the 66S from Ron's website.
http://www.philcoradio.com/gallery/1935c.htm#n
It is possible that your 66S has the correct dial with part number 27-5081, but I'm not able to verify it.
Those are both very nice radios!
Bill
Sent from my Pentium II on the AT&T Dial Network
thank you, Bill, yes the dial of radio 66b is 27-5057, of this i m segure, but i can not find infromation of dial 66-s.
i have this radio, the radio 66-s is small and more nice for me.
thank you, mauricio
