Antique Philco Radio Model 86 Highboy 1929
Does anyone know how much this item weighs?
How much does it weight? I would guess between 50 and 75 pounds if it's comparable to my model 96 lowboy. Compared to many late 20s and early 30s consoles, like a Majestic or an RCA, these are rather light.
Philco 91 Tuning Condenser
There are currently 9269 online users. [Complete List]
» 1 Member(s) | 9268 Guest(s)
