I just don't understand!!!
Well I started working on that 38-17 I got a few months ago. It looked pretty good in the CL pic but when I got it home it really looked AWFUL. I think some previous owner took a can of brush on poly and thew it at the cabinet and then brushed out.
The front panel on this set is a photofinish job so that was going to be a problem. Can't strip it or I'll loose the photo. So I ended up hand sanding it to get the poly off. Shot it with some high gloss Mohawk clear. I was surprised that the photo was in excellent condition very nice looking and has striking grain pattern. Why would some moron do that to a nice set?? The rest of the cabinet is in good shape with a few dings here and there. Still have to do some more stripping of the rest of the cabinet but did the top with some sanding sealer and grain filler. Stripping those little nooks and crannies is a pita but in the end it should turnout to be a nice and somewhat rare set.
http://www.flickr.com/photos/53710524@N0...hotostream
ps. Will post a few pics of the progress when I get a chance
My opinion is that today most people aren't really aware of how wood used to be finished, or even what photofinish is. I have read threads more than once where an unknowing owner of a radio was going to refinish it and sanded the photofinish right off before they realized what had happened.
If you think about it, poly has been around a while now and when it came out it was the "improved" wood finish that needed no where near the maintenance of lacquer. Plus it would not be affected by water the same way.
Gene
Wow, you have your work cut out for you! Must have taken some mighty careful sanding to get rid of the poly on the photofinish. Keep posting progress pictures Terry. This one is going to be interesting.
Jerry
I was surprised at how durable the photofinish was in terms of sanding. I started with 600G but ended up with using 320G to sand off the poly. There was a couple of spots I had to touch up because I wore though the photo but all in all it's pretty tough ( the photofinish). Tnx for the encouragement I need all I can get these days.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 2937 online users. [Complete List]
» 1 Member(s) | 2936 Guest(s)
