1940 Coronado C800 console- COMPLETED!
Thank you 7estatdef for that suggestion. It seems that it will be real simple to do. The radio has a nice warm sound with the set up I am already using, anything to improve that sound is greatly appreciated.
There are currently 9742 online users. [Complete List]
» 1 Member(s) | 9741 Guest(s)
