Philco H-1 Lamp
I am restoring a Philco 41-629 Beam of Light phono and need to know what type of neon lamp was used in the H-1 recorder unit.
Also will need to know where to get them.
Thanks in advance foor any help.
The Philco part number is 34-2432, probably not much help. They are 105-125 volt. Here is a pic of the ones in mine. (I have a 41-629).
[Image: http://i266.photobucket.com/albums/ii273...97cc23.jpg]
Thanks Marv,
One of mine is broken and they are so corroded I couldn't read them.
Will keep looking for one.
Could this work as a replacement? If so perhaps you could find a different vendor that would sell only one or two.
[Image: http://i266.photobucket.com/albums/ii273...e458d.jpeg]
I believe that will work fine. Same voltage specs and electrode shape.
Dbl contact base and all.
Chuck
Thanks Marv and Chuck.
This looks like what I need.
about half the price thru amazon 10 pack $28.96 + 5$ shipping est
http://www.amazon.com/Miniature-Neon-Ind...B0086AOBQU
I think these will work for replacement for a old Distributor testing machine I have! Thanks for the info!
Also available here.
[Image: http://i266.photobucket.com/albums/ii273...f04a4.jpeg]
There are currently 9151 online users. [Complete List]
» 2 Member(s) | 9149 Guest(s)
