Philco T9
I will do the alignment and repair since there's no one closer. It will need to be shipped to Colorado. Is the radio complete?
Don
Don: Radio is complete. Were are you in Colorado, so I can find out how much it is going to cost to ship it. Will mail a copy of service manual with radio, if you don't have one. Alignment: AM band is fine, no problem. All the shortwave bands are off. 16 meter shortwawve band, not pick up very much on it, alignment problem? I not very tech person, if you find a old part in the radio that need to be replace do it. I want this radio working right. Can you give me a ballpark cost of the repair, I known is a hard thing to do. My e-mail address and telephone number: nanquinn649@yahoo.com 518-529-7251. Bill Quinn
