I finished my RCA 5T
As a kid I listened to WLS at night. That was where we heard the Lone Ranger every Monday, Wednesday and Friday at 6:30 PM. That was in the late 40's and early 50's. also they had a country music show "the national barn dance" yes WLS was important to us in that time. Icon_smile
Joe
