seek instructions philco model 765
hello friends
Seeking the instructions zenith radio model 765 to handle.
A greeting.
Here is the schematic...
http://www.nostalgiaair.org/PagesByModel...025284.pdf
hello friends
Now I have the radio zenith scheme but I want the instructions you would have when you bought, for serving a knob or another.
A greeting.
I look like when shopping instructions before operating new
So you want the instructions that came with the radio when it was new? .. That could be tough to find.
