Eico 667
Not sure Im posting this in the right thread so if not ,sorry . I need help with the settings on my eico 667 for some 6b4g tubes. The charts I have seen dont include this and Im rather new to tube radios and I dont know how to determine the settings and I really dont want to make a mistake and ruin these expensive tubes so if anybody has these settings it would really be appreciated.
THANKS
mark
The Eico 666 is very similar to the 667.
The 666 model lists following for 6B4G
6.3, 7, 75, 12315, 11111, 4, 1, 3 5, 3
Thank you very much im going to test my tubes tonight Icon_smile
