Philco 41-315X
#31
looks great
#32
I'm posting hear as we had discussed the pilot lamp earlier. Today I took home a 39-116 with its remote...THIS one still had a lense in it...a clear, faceted lense. Everything with this set appear original....Not sure if I want to pop this out and use one of my red lenses that worked very well in my 42-400...Any thoughts?
#33
is the clear lens 3/8" or was the hole drilled out to accommodate a 1/2" common faceted lens? personally I'd have gone with a faceted glass lens if I could've found one that would fit in the existing hole. as far as I know, and ron demonstrated, these usually came with cheapo plastic lens.
if it looks good with the faceted clear, why not try using a colored bulb?
http://www.pinballlife.com/index.php?p=c...ent=2&pg=1
#34
funny.. I just went back and realized there was all sorts of activity on this thread when I running back and forth from Texas to California (family issues). that radio looks amazing! looking at the escutcheon, you have a much steadier hand than I do. the lines look amazing!
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5561 online users. [Complete List]
» 1 Member(s) | 5560 Guest(s)
