need name of radio please
pick this up no markings at all on this
[Image: http://i1303.photobucket.com/albums/ag14...f5487f.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...8d219f.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...242d2f.jpg]
thanks sam
Westinghouse H-198
http://www.radiomuseum.org/r/westinghou_...2_v21.html
thanks brenda
There are currently 9659 online users. [Complete List]
» 2 Member(s) | 9657 Guest(s)
