Mission Bell 41 Chassis @ Flea Market
Even though the temps got down into the 20's, which is unusual for this area, there was still some activity at the flea market. This is today's find. I bought it because it seemed unusual and is very clean and complete (except for the obvious). Now I just have to find the the rest of it! After a little research, this looks to be an early radio made for Sears back in the 1930's. Couldn't find a picture of what the cabinet would look like but I'll keep searching. Maybe someone out there has a picture? The radio dial is actually inside the cone of the speaker.
Craig R.
There are currently 9960 online users. [Complete List]
» 3 Member(s) | 9957 Guest(s)
