  • 1 Vote(s) - 5 Average
Philco 91 Code 126
#31
My 91-126 has a single speaker setup, not dual speakers.
Neither of the speakers on the twin speaker models is a tweeter; both are full range, one 8 inch and one 10-1/2 inch.
