39-7: The Saga continues
#31
In Korea I would imagine that it would be difficult to do any logging without disturbing the grave-sites that are EVERYWHERE.....Icon_eh
#32
This is true. Family "graveyards" are literally everywhere. I've never seen a "public" graveyard ala western countries. I'm not even sure where they do logging, with the exception of areas where they are in the process of erecting a new city. That's one of the most fascinating things about the ROK: instant cities! In the time I've lived here, I've seen several places go from being rice fields and light forestation to being cities of 500,000-1,000,000 inhabitants in the space of a year or two's time. It's interesting to watch as you drive by an area from week to week.
#33
Are there any import regulations on woodworking products? For instance, if we were to put together a wood working care package would it reach you or be confiscated?
#34
Would depend largely upon what was included.
There are currently 8391 online users. [Complete List]
» 2 Member(s) | 8389 Guest(s)
