41-290 Faceplate Color
I have a reproduction faceplate for my 41-290. It seems way to red (Mahogany) for my radio. Has anybody else had this issue? I'm wondering if I should try a light coat of toner...
I would post a photo, but I no longer have a photobucket account.
Ha. I guess I figured out the picture thing.
Have you looked at the 41 pictures http://www.philcoradio.com/gallery/1941a.htm
I just got what looks the same as yours for my 41-280 and my original is warped & cracked but would guess there was a bit of differences in the originals also.
The pictures of the 41s look like there was a fair difference, but may be just the photo taking.
What did you use to clean up your brass strip? Looks good. I don't want to mess mine up cleaning.
I used GoJo on the station calls for the push buttons and the 3 little clear covers I have.
Have you found any links on what is being used to gin up new push button call letters?
I just used Brasso on a rag to clean my brass strip.
I found a link to scans of original push button call letter sheets. I downloaded the attachment, but don't remember who's thread it was on, so I can't give credit where credit is due. I can send you the attachment if you PM me your email address.
Found the call letters: http://www.philcoradio.com/tech/calltabs.htm
WOW those are greatIcon_mrgreen Thanks
The complete set is also a great resource of the stations licensed so I grabbed both 41 & 42.
Did you print them on anything special? My 7 originals do not seem to be on regular paper. They cleaned up OK with GoJo and a water rinse.
I plan to reuse as many as I can. I have not printed any yet, but will probably use tea stained cardstock, to get that vintage look.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6872 online users. [Complete List]
» 1 Member(s) | 6871 Guest(s)
