Troubleshooting Open Coils - Philco 84B
Hi fellow members-
I am new to radio restoration but have been quickly learning about the process (although I have restored a couple of cars). I purchased a Philco 84B as my first project and am currently replacing the caps, resistors, and bakelites. I am slightly confused about troubleshooting the coils. For the oscillator and antenna coils, I get very low resistance values (2-8 Ohms) while checking continuity. I cannot locate the theoretical values and am hoping these are high enough values to indicate working coils(??)...does anyone know where can I locate these values for an 84? Also, the voice coil and output transformer shows OL so they appear dead. How do you guys figure out if these are good or need rewinding if you get values which are not OL or very high? Should I just assume they are OK and proceed with the rebuild? Thanks for your help-
-The schematic is attached
bdi
Hi, welcome to the Phorum!
Exact resistances of the rf/if coils aren't important, as long as they aren't open. Your range of 2-8 sounds fine.
The field coil should measure 1140 ohms, the primary of the output transformer should be 400 ohms, and the voice coil .9 ohm. If any of those are substantially off or open, the radio isn't going to work. The speaker can be replaced with a modern one, and output transformer, and a resistor close to 1140 ohms at 20-25 watts or so. Hum may be increased without the field coil acting as a choke.
Good luck!
Will
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
There are currently 5562 online users. [Complete List]
» 1 Member(s) | 5561 Guest(s)
