freed eisemann model 51
Anyone have any info on a Freed Eisemann model 51?
Brought one home today that I bought from a friend, and I have not been able to find any info on this one.
It is a 13 tube radio that has been re-capped.
Don't imagine there is anything on the old FM band.
Cool radio though.
P.S. That odd thing that looks like it's on top of the radio is the bottom of a beer sign hanging on the wall. Should have moved it I guess.
murf
[Image: http://i1161.photobucket.com/albums/q509..._freed.jpg]
Interesting.....
Not a well documented manufacturer here in the USA.
Sounds like a 40s set. Can you provide us some photos?
There are currently 7486 online users. [Complete List]
» 1 Member(s) | 7485 Guest(s)
