Volumes level increases after a few minutes..WHY?!?!
Hello all,
My newly restored Philco 610 sounds great, but I have a symptom that may need somediagnosing from you gurus.
Everything works great on the radio. It takes a bit to warm up before I get some sound. Finally, the sound comes on. Then, about 2-3 minutes after it has been running, an instant volume spike occurs, almost like it kicked into 6th gear from 1st. Please note that up until the spike the volume only goes so high no matter how far I turn the dial, so it is almost as if once the spike occurs, the volume is then at it true operating level.
Is this an issue or just an old set symptom?
Thanks again.
Hi
Have all of the paper and electrolytic capacitors been replaced? If not, they need to be. Old capacitors can fail at any time and can cause all sorts of hair-pulling symptoms.
You should also check the tubes, especially the Type 75 which is prone to producing noises similar to a thunderstorm if it is bad.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 7100 online users. [Complete List]
» 2 Member(s) | 7098 Guest(s)
