Andrea Spacemaster
I was just given an Andrea Spacemaster. Six-tube, nine-band selection. Problem is, they're sufficiently scarce that finding info is a bit of a challenge. It took me an hour on line to find a Photofact, but I've got one coming. Icon_biggrin
Nice set GL with it!!!
There are currently 6326 online users. [Complete List]
» 2 Member(s) | 6324 Guest(s)
